BOV limits
The big weave
BOV limits
Post by The big weave »
Looking to do some upgrading, what is the stock BOV good to for boost levels, before it starts leaking?
92ss 5-speed winestone
92 Galant VR4 554/1000
And yes its rally ready
gijonas
Post by gijonas »
Probably a lot.Just throwing my guess out there.
RJ93SS
Post by RJ93SS »
i think i read about 15-17 psi
The big weave
I was asking what it will hold before it leaks.
RJ93SS
Post by RJ93SS »
as said above. 15-17 psi
asc_up
Post by asc_up »
As RJ said, about 16 PSI. Anymore than that and they tend to crack.
BSOD2600
Post by BSOD2600 »
The plastic externally or internally cracks? The sign of a faulty BPV is?
'11 WRX Limited
'94 TW | R.I.P.
asc_up
Post by asc_up »
BSOD2600 wrote:The plastic externally or internally cracks? The sign of a faulty BPV is?
Internally.
When you get into boost but it doesn't hold, so you swap out the BPV with a different one and you're able to hold boost. Lol.
BSOD2600
Post by BSOD2600 »
Alright, that being the case, shouldn't a lot of us with the revtronix stage 2 chip have this occurring? Or are a lot of you running aftermarket BPV/BOV ?
'11 WRX Limited
'94 TW | R.I.P.
gijonas
Post by gijonas »
I had the concern and got a greddy.Never even tried the stocker.
asc_up
Post by asc_up »
I'm running an HKS. I'm not saying that it won't hold at all, it's just how long it will work for at that pressure.
RJ93SS
Post by RJ93SS »
i ran mine ofr a month but only at stage 1. It doesn't take much for a plastic unit to leak. neither my blitz or my hks leak at stage 1.5
BSOD2600
Post by BSOD2600 »
Hmm, wonder if mine is starting to leak... noticed lately is more noisy while on boost (air noise), but my boost during WOT seems solid enough.
'11 WRX Limited
'94 TW | R.I.P.
Mattheww044
Post by Mattheww044 »
I am wondering if mine is leaking now too. I took it off awhile ago and i could BARELY blow through it like at all, I know your not supposed to be able to "at all", but there was a "tiny" leak, but I had no issues with boost. A few months later and here I am. Once i get into the higher RPMs, it will drop 3-4 psi before shifting, sound like a leaking BPV to anyone else?
ciper
Post by ciper »
I know that my02+ WRX units handle high pressures in stock form and even more when crushed in a vice. Its not hard to find adapters that make a flange on the inlet side and these units are very easy to find used.
macipusy
Post by macipusy »
I have blown up quite a few stock BPV, even running 12-13psi for an extended amount time.
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
Mattheww044
yea, I have an Sti BPV (same as your WRX I was told), but Im waiting to put my TMIC on and just do it all at once. Make things a little easier. THe WRX/STi ones are metal though, the stock Leggy ones are plastic.... BOO!!
SubiePrice88
Post by SubiePrice88 »
macipusy wrote:I have blown up quite a few stock BPV, even running 12-13psi for an extended amount time.
same here. Im going on my 3rd now
-Jordan
"Nothing Stings Like a Subee"
1993 Legacy Wagon, 5MT, 220k!
SubiePrice88
whats a good BPV to replace the stock one?
Mine leaks bad and I cant find any good used ones anymore.
Looking for something that will last longer and take higher boost (10+psi) and for a good price
what about this? Legit or not? http://www.siliconeintakes.com/product_ ... a09d4ae070
-Jordan
Post by 555BCTurbo »
I ran a stock one at 20 psi with no problems.
Ditto. I'm running stock BPV at 20 psi without any problems.
brweber352
Post by brweber352 »
This is a great topic and I've been wondering about BOV limits myself recently. From my understanding(which is not always 100% spot on) the BOV/BPV serves two main puposes, staying shut to hold boost and opening quickly to keep the boost from backing up into the turbo.
When does the stock BPV inlet/outlet size become a limit for proper venting? Does this become a bigger concern with higher boost or when you increase the intercooler volume(FMIC), or a combination of the two.
Brian
93'TLegWag171k StockBlock,TD05,HallmanMBC,530cc,Walbro255,shortram,LWpulley,DIS-2,MSDcoil,cxrFMIC,trans cooler/external filter,WRX wheels/brakes,CES w/Borla muffler,QTP elec cutout,REVchip2,KYB GR2,GroupN tops/all fr bushings,STImounts,GSD3 tires,LM-1,etc
SubiePrice88
whoa... NEW BPV from Subaru is $70.00 :shock:
-Jordan
Bdub
Post by Bdub »
I picked up a VW aluminum one on Ebay. It works very well, although the dia. is larger than stock, so hoses need to be adapted to work with it.
Through The Generations...
91 SS 4eat
95 LSi 4eat- Sold
07 2.5i 5mt- For Sale
13 STI Sedan
