Weird sound, CV? Wheel bearing?
Posted: Wed Aug 19, 2009 8:53 pm
by Apex3
Cars making a weird noise when I drive, I thought maybe it was a CV, but I thought those usually clicked, then I thought it might be a wheel bearing, but those usually whine.
What it does is it has a rythmic sound coming from the front, it's not a clicking or banging kind of noise, almost like a rubbing sound but I know that's not it, and you can feel it about as much as you can hear it. Obviously it speeds up when I speed up, but it may be quieter or louder depending on speed, and it does get louder when I turn either direction. I'm having trouble figuring out what side it's coming from too. It should be noted that the sound was there when I bought the car stock, and I'm on my third set of tires and I have new springs/struts, so it isn't related to those.
Normally in this situation I'd just start replacing things until it went away, but I'm a bit low on funds so I'd really like to figure out what it is first...
I do have a CV boot that is leaking, but not torn, I put more grease in it and nothing changed at all.
Posted: Wed Aug 19, 2009 9:04 pm
by gijonas
Posted: Thu Aug 20, 2009 12:39 am
by SPUMONI_RT
Did you check your brakes?
Posted: Thu Aug 20, 2009 5:51 pm
by entirelyturbo
I've never heard a wheel bearing whine.
It usually sounds like a low-pitched hum, or if they're in really bad shape, a scraping sound.
It will get louder with speed, and probably get louder when cornering due to the weight transfer.
So yeah, what you're describing sounds like wheel bearing(s).
Posted: Thu Aug 20, 2009 6:14 pm
by gijonas
On the flip side of that,sometimes they will shut up upon cornering for the same reason.
Posted: Fri Aug 21, 2009 1:04 am
by log1call
If it gets louder when cornering then probably bearing. If it comes and goes with throttle or bumps in the road I'd suspet axle/inner cv.
