Converting 2WD to AWD
Xander_X
Post by Xander_X »
Anyone done it? Can I do it just swaping parts? I could just buy an AWD I know but my car is in such good condition and less than 60K on it. I'm going to be buying an STi soon for a daily driver and thinking of turn this car into my project track car. And whats needed?
Rear hubs, halfshafts, diff, front diff, driveshaft, ... um ... anything else? Tranny? Computer?
I think I'd rather do this than buying one too because then it gives me someone more to work on. I'm always a little sad when I get a project and it's done.
Bare in mind I can get all the parts at my local Pick N Pull for cheap so I'm not worried about price. Well all the parts but an LSD ... which I would want if I was going to do it.
99 Toyota Celica GT
91 Celica GT-Four All Trac
89 Toyota MR2 Supercharged
2010 Toyota Tacoma SR5 Quad cab
2010 Acura RDX turbo
Transmission, gas tank, drive shaft, rear diff, subframe, axles, hubs, struts, springs. If you ever want a project, you can restore mine. I hate doing the work, I like the finished product. Especially when it will allow me the space to build a vehicle from scratch.
Xander_X
Post by Xander_X »
i'm guessing the gastank because the it has a hump for the driveshaft?
99 Toyota Celica GT
Check out the stick in this forum, and specifically most post. I've got a detailed write-up on the procedure.
the conversion is real easy... i went off the detailed writeup as listed above for some stuff, but it's all direct bolt on so you'll be fine.
