Interior lights
92legacyss
Interior lights
Post by 92legacyss »
The 10A fuse under the hood that is for my interior lights keeps blowing i cant even put a new one in it just blows any suggestions?
92 ss 5MT..TD04, 02' Wrx TMIC, XS power Atmos. BOV and Gripforce stage 2 w/ WRX OEM Flywheel, Equal length headder and catless uppipe. Open DP and soon tobe CBE, WRX struts and springs, MBC
You've got a short.
Unplug each device on that circuit, check if the fuse does not blow right away, and then plug each device back in, and see which one causes the fuse to blow. Investigate that device/wiring.
92legacyss
thanks i was afraid thats what i was going to have to do but oh well .
roundeye
Post by roundeye »
try a 20 amp. if it blows, you've got a dead short. if it doesnt, start looking for the smoke. crude, but effective, and wont be enough current to do any damage.
BSOD2600
Post by BSOD2600 »
There is a good reason why it's a 10A fuse instead of 20A -- so wires don't melt or other things create an arc.
'11 WRX Limited
'94 TW | R.I.P.
The big weave
Post by The big weave »
Also do you have fog lights or something that you taped off the lights? that can cause things to blow, if so just put a bigger fuse in and it should fix the problem
92ss 5-speed winestone
92 Galant VR4 554/1000
And yes its rally ready
92legacyss
No fog lights but i tried the 20A fuse a few days ago and it blew right away so i guess i get to start tracing back everything on that cicuit with a multi meter
magicmike
Post by magicmike »
roundeye wrote:try a 20 amp. if it blows, you've got a dead short. if it doesnt, start looking for the smoke. crude, but effective, and wont be enough current to do any damage.
when the rated fuse blows try a bigger fuse? That is the worst advice you could give a person. I have a better one, just jam a penny in there so it will work.
But on a serious note, the only way to find the short is to do as Josh stated.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
roundeye
Post by roundeye »
i've used this to find shorts on cars nothing else would. like a trailer light converter, that the owner didnt know was there, no visible wires, which kept blowing taillight fuses. tracing all the wires would have taken hours. popped in a 30amp(it was a 20), 5 seconds later, found the shorting converter, buried under a rear interior panel. wasnt anywhere near the rest of the wiring for that circuit. tracing wire doesn't pay very well on flat rate. if a circuit is designed to support 10 amps at a possible 100% duty cycle, running 20 through it for a few seconds wont hurt anything. and if you have anything other than a dead short, you can spend hours looking for the wire barely touching another, or the chassis. if, however, like this, the larger fuse blows instantly, you know you've got a dead short to ground. you can use a lightbulb as a short checker in place of the fuse. remove the loads from the circuit, put the bulb in, and it should light. when the short is removed (by unplugging/ etc.), the bulb will go out.
92legacyss
Thanks man i'll try that
