Which driveline do I need?
Hey guys I posted about a wierd sound coming from the tranny "area", and after having a friend look at it he said that it sounds like its coming from the driveline, meaning the U-joints are going out. For those who dont know I have a 03 WRX tranny and the center diff is welded and front axels cut. So which driveline can I use to replace mine? can it be from an NA? I would assume it needs to be a 5speed, and also does it need to be the 3.90 or does that matter either? Thanks ahead of time
