Looks like coolant/oil sat too long and so the cylinder walls are corroded and practically seized. So the whole thing is up for sale for someone who wants to bore it out and rebuild, or just steal the awesome parts (heads, cams, intake manifold...etc all in great condition.)
If you're looking to build/use it, I also have the ecu (20R, so it's TT) and wiring to go with it if I get asking price. WILL ALSO THROW IN THE STOCK TMIC
Intake manifold was powdercoated by me wrinkle red (see shitty pic)
Does not come with inlet tube or big TMIC seen in pics.
Probably won't take pics of the damage, you can just assume you'll need to work at it to get it right.
Looking for $500 Plus Shipping. And if you just want the heads/cams/intake I WILL separate from the block since it's worthless...
P.S. I'm never on here hence my one post (this one) But I'm an active member on Sl-I, Nasioc, AWD Pirates (for those of you in CO) and ebay (alkalinequatro) and all have good rep/feedback
