the latest...turbo timer problems
nicv217
Post by nicv217 »
hey i just wired in my safc neo on my 93 subura legacy and it works great. but now for some reason my turbo timer works sometimes. the car will shut off and the turbo timer will stayin running. anyone have any ideas. the turbo timer isnt connected to the ecu right? any help will be great
I have removed the picture from your signature. Images in signatures are not allowed.
As for the turbo timer, it should be tied into the ignition wiring. Once the key is turned off, it should start counting down and then cut the power after a specified time. What brand/model is the turbo timer?
