any one know if these are any good? and if they will fit my 97 legacy?
ehe thanks
http://www.rallysportdirect.com/shop/wh ... -2626.html
Whiteline STi Adjustable Front Endlinks
subbieedude!
/// life begins at 20 pounds of boost
subbieedude!
I'm not a big fan of the kartboy endlinks because the hole on the endlink is larger than the bolt being used. This can cause forces to pin pointed more at the corners than being evenly distributed across the metal collar in the end link.
I know a lot of people use the kartboy end links without any problems. I just wasn't a fan of how they were setup.
