Whiteline STi Adjustable Front Endlinks
Posted: Mon Sep 21, 2009 4:36 pm
by subbieedude!
any one know if these are any good? and if they will fit my 97 legacy?
ehe thanks
http://www.rallysportdirect.com/shop/wh ... -2626.html
Posted: Mon Sep 21, 2009 8:04 pm
by jamal
the through hole on the endlink is M10, but the through bolt in the control arm is M8. If you drilled out the control arm mount they would work.
kartboy makes nice endlinks that fit.
Posted: Mon Sep 21, 2009 8:40 pm
by subbieedude!
alright, thanks i take alook at some kartboys before i decide
Posted: Fri Sep 25, 2009 5:36 pm
I'm not a big fan of the kartboy endlinks because the hole on the endlink is larger than the bolt being used. This can cause forces to pin pointed more at the corners than being evenly distributed across the metal collar in the end link.
I know a lot of people use the kartboy end links without any problems. I just wasn't a fan of how they were setup.
