Rear Diff question
magicmike
Rear Diff question
Post by magicmike »
I searched for a half an hour so don't flame me.
I have all 4 wheels off the ground.
When I spin 1 of the rear wheels the axle shaft spins with the wheel and the other wheel does not move at all.
When I switch to the other side it does the same thing.
Is this normal? I figured I'd ask while I had the car off the ground.
I remember on my old wagon that when turning one rear wheel the other would turn in the oposite direction, like the front diff.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
Buffman
Post by Buffman »
mine kinda does the same thing. If you rotate the one side it will slowly move the other, but doing the other side doesn't move that side..
1992 Legacy LS Special Wagon..
mexicanzero
Post by mexicanzero »
yeah thats normal the movement will take the path of least resistance just like electricity
if you hold the driveshaft keeping it from spinning and spin one rear wheel the other side will go the opposite way.
-Alex
LIVE LOUD, ROCK HARD!!@
1992 Subaru Legacy SS 06 WRX TMIC TD-04 MSD coil 3" turboback H&R coils GR2 shocks fsb 20mm rsb 22mm stage 2 chip
2003 silver wrx wagon 5 spd just bought!! stock for now...
Matt Monson
Post by Matt Monson »
It's normal. You have an open differential.
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
magicmike
Post by magicmike »
ok, thanks guys
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
Buffman
Post by Buffman »
guess Im used to RWD open diffs that since the trans is in park, the ds doesn't move :)
