Can Someone Identify This Transmission?
A1Fiddler
Post by A1Fiddler »
I got a parts car which has had a tranny swap in it. The transmission code reads TZ102ZB3AA - N7. I've been searching and haven't been able to come up with much except that it looks like maybe an imported tranny from a twin-turbo Legacy. Can anyone verify that this transmission will hold up to my EJ22T's torque if I swap it into my car?
-Andrew
'92 Legacy Sport Sedan - EJ22T, 4EAT, AWD - Snorkle Delete, Custom Grounding, 3" Catless TBE.
fishbone79
Post by fishbone79 »
Turbo, BF-5? I believe 93-94 JDM spec GT... ala BF5D49P? JDM for sure. My data sheet is not so great with the autos, someone please correct me if that sounds wrong.
Cheers,
morgan
1992 Legacy BF
wtdash
Post by wtdash »
Running stock boost the tranny should be fine. Plus if it's a JDM most (all?) had to handle more HP than the USDM model anyway.
Found this thread on USMB: http://www.ultimatesubaru.org/forum/sho ... 398&page=3
Says the plugs match, but sounds like it's a different ratio...4.11 or 4.44 vs. your 3.90?
Can you put the donor car up in the air and move the rear wheels and count the revolutions compared to the drive shaft?
Also, saw THIS on NASIOC.
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
A1Fiddler
Post by A1Fiddler »
Thanks for the help guys.
I did run across that USMB thread before. I know the previous owner had a 3.9 rear diff in it, but that may not mean anything. I really just wanted to verify that it was from a JDM turbo model because they had more HP/TQ than the USDMs so I'm sure the tranny will hold up fine.
Unfortunately that NASIOC thread doesn't help much since nobody replied.
Matt Monson
Post by Matt Monson »
There are no internal differences to the turbo and NA trannies. If the tranny is healthy, you will be fine.
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
All_talk
Post by All_talk »
Matt Monson wrote:There are no internal differences to the turbo and NA trannies. If the tranny is healthy, you will be fine.
I was always under the understanding that the turbo 4EATs had more disks in the clutch packs for 1-2 and 3-4. Not true?
Gary
Gary
They were talking about the 5MT transmissions.
