spring info for kyb gr2 strut for legacy 92-94
yazmo
Post by yazmo »
hello i found some spreing here and wonder if this would fit my legacy kyb 92-94 strut i got top mount from monroe lol
here the spring i am looking at
http://www.annonce123.com/ann-wrx-coil- ... _idH944063
since im about to install my strut this next week-end
i need a respond asap
i would like to change the spring too or i may have to leave them on stock spring
n2x4
Post by n2x4 »
No, those won't work without getting more WRX parts. You'd need the proper tophats to match.
SUBARUEHS Racing
Primeza
Post by Primeza »
It would help to know what year your car is and if it is a wagon or a sedan. Assuming you have a 92-94 and according to:
http://bbs.legacycentral.org/viewtopic.php?t=22419
You should be able to use 02-03 WRX non-tapered rear springs. The front springs, you should be able to use 02-07 WRX springs as they are the same, but as n2x4 says, you will need at least matching front WRX tophats and spring perches.
So you need to confirm with the seller that the springs are for an 02-03 WRX with straight rear springs, not tapered rear from an 04+. Below is a link to a photo of an 04 WRX tapered rear spring. From the photo in the link you posted, they look straight, but you should confirm with the seller. It would probably also help to know the spring rate of those springs and possibly how much drop you can expect on a WRX.
http://chufamilyphotos.com/gallery/main ... temId=1166
Here is a photo showing the difference in the front spring.
I cannot comment on how your combo will work or how much drop you will get because my setup is quite a bit different than yours.
92 Legacy TW - 225k and counting
yazmo
Post by yazmo »
ok thx ill ask him i appreciate that
