wtb spring upper seat, rubber, spacer rear lwr seat and rub
yazmo
Post by yazmo »
yeah like the title say i am looking for a good shape spring seat and rubber for the front and rear, also need the lower seat rubber i think part number is 20375AA002
its seem these get one be find on subaru dealer and there are definitly not cheap. if i nkow from the start i would get coil over right from the beginning.
i when to install my kyb gr2 strut and my new top mount and i find out that the perch are barely crush.
yazmo
Post by yazmo »
nm guy i by these from subaru dealer cost me around 180$
Primeza
Post by Primeza »
When I did my swap I purchased some of the misc bits from a guy, ten80 on Nasioc. Here is a recent for sale post from him. Just PM him and see if he has what you need.
http://forums.nasioc.com/forums/showthr ... ?t=1880552
From what I remember the new and old bumpstops were the same (as long as you get 04+ parts, I think the 02-03 rears are longer.) and I trimmed them a bit to make them shorter. I used newer washers including the concave front ones. I believe I used the rear upper rubber spring seats, but mine is a 92, not sure if you have a 90-91. I do not know if the lower rubber pieces will work.
92 Legacy TW - 225k and counting
