4eat transfer clutch replacement writeup?
magicmike
Post by magicmike »
Is there one? I've heard some funny noises in the snow from my 4 eat when boosting hard. I think this may be on its way out.
I'm talking about using a kit like this
http://www.levelten.com/Level_10_PTS_Su ... -15000.htm
to replace these:
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
magicmike
Post by magicmike »
Found this while browsing the interweb. Saved a file for ref.
http://www.subaru-faq.ru/pdf/transmission/4eat.pdf
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
tturnpaw
Post by tturnpaw »
simple fix...remove clutches and weld it in the basket. Theres enough give in the front diff and rear to keep any serious problem from arising. Then you will have peace of mind in knowing theres a continuous 50/50 going out.
tturnpaw
Post by tturnpaw »
You won't break anything, but it is quite annoying around corners. Steering is much harder around corners as well.
WhiteLegacyGuy
Post by WhiteLegacyGuy »
This is all for a 5-Speed the 4eat is wildly different.
93 Legacy Sport Sedan, Eagle/Wiesco EJ22T DOHC, GT3782vnt turbo at 28psi, Hydra Nemisis 2.6, RC1200cc injectors,
Built 4EAT. AP-racing Sure-trac R160. Brembo GT BBK. JDM Legacy B4 Bilstein struts w/ground control coilovers.
VNT FTW
magicmike
Post by magicmike »
Thanks for the input guys. However, I'm not looking to turn my car into a drift machine. I already have a rwd car that I can barely drive in the rain.
Like I stated above. I'm looking for some material to be able to do the service myself on my 4eat.
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
wtdash
Post by wtdash »
USMB info: HERE and
HERE help?
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
magicmike
Post by magicmike »
wtdash wrote:USMB info: HERE and
HERE help?
ok so wait a minute... I don't have torque bind. I have a strange noise and rear wheel slippage at high boost levels only in the snow. I though it was the clutch pack.
Hum, Maybe I have a problem with sol C?
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
