looking for rebuilding short block tips
92ss satinsvoice
Post by 92ss satinsvoice »
ok, im going to reassemble my short block again. this time by my self. the rods are already on the crank ( i had a friend install these in the first rebuild) and i have the mains ready to go on the block halfs plus new rings too.
so my questions are:
how much silicon do i use to seal the block?
do the notches in the bearings face each (same side) other or are the apposed.
if theres any other things i must know while installing the crank and bolting up the short block please let me know. i will look for the torque sequence spec's for the block.
Thank you all very much!
Andy
94 L n/a 5spd, Rip
91 ss champagne - Rip
88 Leon GL Hatchback - DD
gijonas
Post by gijonas »
You want to use enough sealant to fill all voids but not so much that it all squeezes into the crankcase when you tighten it,just use common sense on that one.As far as the bearings go you should only be able to put them in one way due to the little bent tabs on the bearings which lock into the block,so yes the grooves will match up.
I'll second the silicone comment. You do not want to get carried away.
Do you have a rebuild kit with the washers/seals, etc? Is it OEM?
92ss satinsvoice
yes i bought all the o-rings and seals from the dealership. i never use any aftermarket seals. ive learn the hard way why and we all know what i mean. Thank you guys very much this should be easy to do then.
LIVE ON THE BBS!!!
Andy
94 L n/a 5spd, Rip
log1call
Post by log1call »
It's better to use an anarobic sealer like loctite these days.
The anarobic sealers don't harden unless they are clamped between metal surfaces and so the squeezed out stuff disolves into the oil and comes out with the first oil change.
Silicon is diabolocal for getting into oilways and causing serious damage.
I'm a mechanic and I'd never use silicon for anything but sumps that are designed to use it.
I'm not sure why you are doing a second rebuild but I'd strip those rods and start again with everything clean as new. Even if there hasn't been a problem you need to clean and lube those shells.
Cleanlinsss is next to godliness when it comes to motors.
Yeah, I'd probably have to agree on the anerobic sealant. The FSM recommends using one....I forget the actual threebond name. I picked some up for my rebuild.
log1call
Post by log1call »
AnErobic, anErobic... must learn to spell!
brand
Post by brand »
It's actually anaerobic, so don't be too hard on yourself ;)
91 SS with a bunch of parts waiting on the shelf
94 SS with things and such
08 STI with stuff and junk
log1call
Post by log1call »
Hell, I can't even pronounce that one.... I give up!
92ss satinsvoice
anyone have the torque sequince for the short block? i have all the bearings in and the crank ready to go.
Andy
94 L n/a 5spd, Rip
It'll be in the FSM's I posted here
http://bbs.legacycentral.org/viewtopic.php?t=14485
92ss satinsvoice
the links i need aren't working for me.
Andy
94 L n/a 5spd, Rip
Which ones do you need? The 92 FSM? For whatever reason the phpbb software doesn't like & in the links.
Go to the main link, and navigate to the 92 FSM
http://www.main.experiencetherave.com/s ... ual_scans/
92ss satinsvoice
thank you josh very much for your help. got the info i needed. :wink:
Andy
94 L n/a 5spd, Rip
