4wd or 2wd
spicer
4wd or 2wd
Post by spicer »
i have a 92 gt legacy turbo with a vf8 ej20 turbo engine.
now prob is i cant tell if its 4wd or 2wd as very time i step on the gas on loose gravel the front wheels spin up, or if im at a stop sign or at a standing start on the road, when on a hard take off and on boost the fronts just smoke up!!!
any ideas on why is this?
fishbone79
Post by fishbone79 »
Look underneith... Do you have a driveshaft and rear diff? If you do, is it an AT with the FWD fuse stuck in? If not, sounds normal-ish....
Cheers,
morgan
1992 Legacy BF
spicer
Post by spicer »
any everything there. no fuse stuck in. just thought it should be 4wd.
Bosco
Post by Bosco »
It certainly should be awd.
did you make absolutely sure the entire drive shaft is there? Sometimes, if experiencing bad torque binding and if the fuse doesn't work out, people will remove the rear-most section of drive shaft to make it fwd and stop the binding.
Are you in the US? is this a modded USDM Legacy, or is it a JDM/EDM with stock ej20 & vf8?
Just curious.
94 Legacy Touring Wagon - 5MT Swapped and now with 100% less turbo!
02 Legacy L wagon - Auto
92 Legacy L fwd auto
ChickN
Re: 4wd or 2wd
Post by ChickN »
bump...
havin the same issue except mine usdm and and stock....just started the other day...i can do 6k burnouts in 4wd hardly moving....again just the front wheels spinning...sorry for the hijack!!
ciper
Re: 4wd or 2wd
Post by ciper »
Please specify if its an automatic 4eat or manual 5mt
ChickN
Re: 4wd or 2wd
Post by ChickN »
4eat here....ciper i did the test you told me to in my tread and the front wheel spins while the other does not...is this the same instructions for a 4eat as well??
