Hey guys, I'm new here.. first post. I did some searching but was unclear on whether or not this will work? What I found was either spring only or strut only interchangeability. so here is my question:
I have a full 04 wrx suspension (strut, spring, top hats) all assembled, I just picked up a 93 legacy turbo and was wondering if it is possible to remove the leggy suspension as a whole assembled (strut, spring, top hats) and put in the 04 wrx suspension as a whole? so basically a direct swap?
If not what can i use from the 04 wrx suspension to combine with the leggy suspension to make it work? thanks guys.
Jason
Question about suspension interchageability
i have a set of 04 sti struts in my 93 leggy and all i had to do was change the rear top hats to 91 top hats beacsue of the taper of the rear spings. dunnno about WRX stuff tho
Massimo Narini
93 legacy Turbo (aka Gracie)
-Turbo XS boost controller(6/12psi), WRX TMIC, STI sways,04 STI struts, 3'' DP, lightweight pulley,
