federal emission mode??
Hey guys just wondering why this mode is ON? Using revtronix it says it is turned on and enabled via a wire. Isn't that the california thing?? Or does the chip enable this. I am running stage 2 revtronix btw.
BSOD2600
Post by BSOD2600 »
I believe this is the same thing as 'california emissions' mode shown in B10scan...
'11 WRX Limited
'94 TW | R.I.P.
ya is yours on? It wasn't on with B10scan.
If it's in "federal" mode it is setup for all states other than california. This would show up on the select monitor under F/C and the light would be on.
So it sounds fine.
perfect also asked on revtronix got the same answer thought federal mode was california mode doh..
