Its the 90 degree pipe that leads from the Turbo silencer delete (read, Coffee cup mod) to the Turbo.
The nipple that the BPV leads to broke off when I tried to remove the little pipe that was inside it. Patched it back together best I could but it leaks a bit. Car hasnt been 100% since I did the intercooler install like a month ago and Im sick of it! Contact me ASAP!
Thanks in advance.
I did the same. You might want to go with a new one though, I know they're expensive, but you don't want to end up with an old brittle part that's gonna break anyway. Used rubber parts aren't a very good idea.
