It seems like everytime I check my spark plugs there is some water build up in the hole. Atleast one time it was causing some misfiring. The upward angle of the hole and less than perfect fitting seals on the plug wire means water can get it and it can't get out.
I use lots of dielectric grease on the plugs and that keeps misfiring at bay for a while, but I think I may try using a little bit of high temp silicone around the rim of the plug hole.
Has anyone here tried this before?
Water on spark splugs & sealing them up
+1
from my build thread
"the quality difference both in feel and fit and finish was remarkable. while the BA's seem to even allow water to get into the spark plug hole, the NGK's are a nice tight, solid fit with a very positive snap as you put them in. I got the NGK's from autopartswarehouse.com for 36.95+ shipping which was the cheapest I could find. gotta pay for the good stuff I guess.
major quality difference
"1994 Touring Wagon: ruby mica, 5mt swapped
A good set of wire will keep water out of the holes. Both the NGK's I have, and the Magnecor's kept the water out.
Legacy Konig
+1 for what they all said. Iv never had a problem with them NGk wires.
93 Imp wag, 94 Imp wag WRX swap, 99 Imp Sedan WRX swap, 01 Imp Outback Sport, 05 Outback XT, 00 Outback, 98 Outback, 93 Leg touring, 93 Leg wag, 94 Leg wag lifted ej22t swap, 79 Brat 4x4 EA81 4spd d/r swap, 97 Crown Vic lifted
