SVX Injector size?
martimus919
SVX Injector size?
I picked up some SVX injectors and would like to use them for my SS for when i get the Stage 2 Revtronix chip, but i don't know what size they are. So any one got any idea of where find out the size?
I'm not sure of the size, but considering that the SVX was rated at 230HP from 6 cylinders (~150HP if it was 4 cyl), the injectors are most likely about the same as any other normaly aspirated injector. In other words....Stock SS injectors are most likely higher flowing.
martimus919
From HERE:
Td
and HERE.The SVX injectors are side feed and from what I can tell are rated somewhere between 260-275cc/min.
Based on Opposedforces.com the SVX injectors are a unique part number, but I'd bet the EJ22/25 red injectors would also work as they are rated around 280cc.the injectors are a different story as they are 275cc jobs that are going to be maxed out at 250 HP.
Td
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
The eg33 is a 2.2 with 2 additional cylinders.Therefor the injectors are most likely the same parts as the ej22 N/A.
