SVX Injector size?
Posted: Thu Nov 05, 2009 2:22 am
by martimus919
I picked up some SVX injectors and would like to use them for my SS for when i get the Stage 2 Revtronix chip, but i don't know what size they are. So any one got any idea of where find out the size?
Posted: Thu Nov 05, 2009 3:05 am
by PhyrraM
I'm not sure of the size, but considering that the SVX was rated at 230HP from 6 cylinders (~150HP if it was 4 cyl), the injectors are most likely about the same as any other normaly aspirated injector. In other words....Stock SS injectors are most likely higher flowing.
Posted: Thu Nov 05, 2009 6:31 am
by martimus919
Ya I was afraid of that
Posted: Mon Dec 07, 2009 7:12 pm
by wtdash
From
HERE:
The SVX injectors are side feed and from what I can tell are rated somewhere between 260-275cc/min.
and
HERE.
the injectors are a different story as they are 275cc jobs that are going to be maxed out at 250 HP.
Based on Opposedforces.com the SVX injectors are a unique part number, but I'd bet the EJ22/25 red injectors would also work as they are rated around 280cc.
Td
Posted: Mon Dec 07, 2009 8:24 pm
by gijonas
The eg33 is a 2.2 with 2 additional cylinders.Therefor the injectors are most likely the same parts as the ej22 N/A.
