ej22 16 valve turbo 1992
I am in need of an exhaust header for an ej22 that is light weight. O.E.M is to heavy for my application...would really like some direction with this. thanks in advance...btw the turbo is now removed.
You should post this in the Parts Shed, after you edit your profile and put in your location.
