Samco Turbo Intake Hose
Someone posted this on NABISCO. Not sure if it will work for our cars.....if so, might be an option to replace the stock piece.
RallySportDirect is the only place I've seen it yet.
Here's a pic
Samco part # TCS416IND
Mattheww044
Post by Mattheww044 »
someone buy it and try it out! haha
I have no problem doing that, but wanted to get a little more info on it.
dscoobydoo
Post by dscoobydoo »
IF I get the other car going soon, I will just up and get it.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
asc_up
Post by asc_up »
It WILL work. My friend has it on his 20G swapped GC. I tried to buy it off of him, but he wouldn't budge :(
Post by SubaruNation »
thats sweet since the OEM ones are $90, this is much nicer
Mattheww044
May be a stupid question, but what would be all the benefits it would provide?
asc_up
Post by asc_up »
It would be smooth on the inside and it wouldn't be prone to hardening and cracking (like the stock one). Otherwise, there's not much else.
Mattheww044
thats kinda what I was thinking, it woul mostly be cosmetic, besides the flexibility. I wasnt sure if it woulda had better flow or anthing
asc_up
Post by asc_up »
It would probably be about the same gains seen as when the WRX and STi get the Saamco turbo inlet hoses (the ones that go under the manifold). There are probably cheaper, more effective mods that could be done, but it's not like this one would hurt.
The inlet spots are slightly different for the PCV system. That can be modified....but I probably won't mess with it, since the PCV system is already convaluted.
NICO
Post by NICO »
looks like a very nice part, nice find.
Ya pretty sweet to bad its kind of expensive. I guess ill just get the OEM part instead. It is only $50 here for that inlet on the turbo.
Re: Samco Turbo Intake Hose
Updated Links
That looks like the exact same geometry as the stock EJ20G piece. It'll require a tiny bit of finagling to make it fit a stock EJ22T, but just a tiny bit. The angle of the BOV fitting is slightly different and one of the PCV fittings is in the wrong place.
Dave_J
Post by Dave_J »
And they seen us coming. $444 list is totaly ludicrous. Hope they have 1000 units in stock and sit on them. I'd pay 1/4 that but thats it.
Retired US ARMY SIGNAL CORP
65 B-Cuda Formula S, 78 Dodge Little Red Express Truck, 08 Suzuki Burgman 650 Super Scooter, 94 Legacy Touring wagon.
Doaomo
Post by Doaomo »
Crazy! That price just blows my mind!
You may be able to order it overseas and have it shipped cheaper.
