Blew out my illumination system
macipusy
Post by macipusy »
So I was screwing around and testing where to run my switch power for the relay for my new driving lights. I thought to test the illumination power from the lighter. I removed the bulb and connected those two wires with the power to the switch for the driving lights. Seemed to work at firs until I adjusted the illumination knob on the steering wheel....the fuse blew.
I disconnected the power for the driving lights and replaced the fuse....it blew again as soon as I turned the lights on. I disconnected the two wires which ran through the lighter illumination bulb and replaced the fuse....the illumination works but only full power, there is no adjusting to dim.
Where should I start to check for a short?
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
macipusy
Post by macipusy »
Does anybody have the illumination electrical diagram, if there is such a thing?
maciek puszynski
16 WRX | 6mt | fa20
Download the engine & electrical manual for the 92 legacy from me. The information will be in there. You may have blown the illumination control unit.
http://bbs.legacycentral.org/viewtopic.php?t=14485
macipusy
Post by macipusy »
Where is the illumination control unit located physically on the car?
maciek puszynski
16 WRX | 6mt | fa20
magicmike
Post by magicmike »
My fsm suppliment shows a black 6 pin connector on the right side of the radio opening in the dash thats connects to the Illumination control unit.
Cant see how to access it. I'd start with the radio trim first. Might be on the left side of the glove box.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
To the right of the radio, left of the glove box as Mike pointed out. I'd take the glove box out. You should be able to access it then.
http://www.surrealmirage.com/subaru/fil ... tion05.jpg
macipusy
Post by macipusy »
Found it, replaced it and it works....thanks guys
I took the glove box out and accessed the 3 screws from there.
maciek puszynski
16 WRX | 6mt | fa20
magicmike
Post by magicmike »
I love it when a plan comes together...
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
