KYB GR2 struts with which of these springs?
SiCkSTi04
Post by SiCkSTi04 »
struts will be here next week. got a couple springs laying around from.. 03 wrx wagon, 05 wrx sedan, 06 sti springs
which would actually work or be my best option "upgrade" from using the stock springs oh will height be an issue? the wheels i'm using are from a 2006 2.5i impreza 205/45/16 thanks!
SiCkSTi04
Post by SiCkSTi04 »
found this on one of the sticky threads..
If you have a 90-91 Legacy, you can use 04-07 Impreza springs as direct replacements. The 90-91 Legacies have tapered rear springs like the 04-07 Imprezas do, so they will fit. Below are 04 WRX sedan part numbers as an example.
04 WRX sedan front springs: 20330FE861
04 WRX sedan left rear spring: 20380FE830
04 WRX sedan right rear spring: 20380FE820
so i'll be using my wrx 05 springs for now, stilling searching tho.
Bdub
Post by Bdub »
I'm using 04wrx springs with gr2's. Ride height isn't all that much of a difference compared to stock. Slightly stiffer.
Through The Generations...
91 SS 4eat
95 LSi 4eat- Sold
07 2.5i 5mt- For Sale
13 STI Sedan
