KYB GR2 struts with which of these springs?
Posted: Fri Nov 13, 2009 11:15 pm
by SiCkSTi04
struts will be here next week. got a couple springs laying around from.. 03 wrx wagon, 05 wrx sedan, 06 sti springs
which would actually work or be my best option "upgrade" from using the stock springs oh will height be an issue? the wheels i'm using are from a 2006 2.5i impreza 205/45/16 thanks!
Posted: Sat Nov 14, 2009 5:43 pm
by SiCkSTi04
found this on one of the sticky threads..
If you have a 90-91 Legacy, you can use 04-07 Impreza springs as direct replacements. The 90-91 Legacies have tapered rear springs like the 04-07 Imprezas do, so they will fit. Below are 04 WRX sedan part numbers as an example.
04 WRX sedan front springs: 20330FE861
04 WRX sedan left rear spring: 20380FE830
04 WRX sedan right rear spring: 20380FE820
so i'll be using my wrx 05 springs for now, stilling searching tho.
Posted: Sat Nov 14, 2009 7:24 pm
by Bdub
I'm using 04wrx springs with gr2's. Ride height isn't all that much of a difference compared to stock. Slightly stiffer.
