I'm doin a cheap ej22na to turbo build with heads and pistons being the major components being changed. Ofcourse with changeing the pistons I wanted to get new rings and a boardmember recomended topline as the place I should get them from as the dealer was way to high. I have compared turbo piston rings to n/a and the compression ring is thinner on the n/a piston. When I recived the rings from another boardmember who got them from topline they are of n/a spec with the thinner top ring. When I went to there site the part numbers are the same for n/a and turbo but the rings are definatley diffrent. Anybody have any experience with the topline brand rings? I will get exact measurements in a few but if I use these rings in the turbo pistons there will be slop!
Ring thickness:
Na 1st 1.20 mm
2nd 1.50mm
turbo
1st 1.50 mm
2nd 1.50mm
redline replacements
1st 1.20mm
2nd 1.50mm
Also the motor is pretty much torn down and changing the bearings wouldnt be much harder. As far as i know the motor runs fine i havent heard it run personally but everything seems ok so far so if i tear it down whats the likely hood that i could just put new mains and rods in it wothout machineing and be fine??
ej22e to T piston ring problems/ rebuilding advice..
jdmleggy97
You should be able to just put in new bearings without any problems. That's what I did when I rebuilt my turbo motor.
One thing I'll comment on is that you may want to get the cylinder honed lightly. Even if the cross-hatching is there, it may be worn down enough to the point where if you put in new rings, the rings won't seat properly, or may take longer to do so.
Just a thought.
Just a thought.
jdmleggy97
You could try it yourself. I've heard mixed comments about the do-it-yourself honing kits.
Anyone else have any comments?
Lunatech
Just do it. Use plenty of light weight oil, I usually use WD40. Be sure not to push to far into the cylinder or pull to far out. It just takes a few seconds per cylinder then clean well and assemble. This may not be the prescribed or best method but it has worked for me many times.
Robert,
Rio Red 1990 L sedan 5MT at least 302000 mi. and Spruce Pearl 1996 Wagon 4EAT 245000 mi.
georryan wrote:
Don't knock him for thinking outside of the box. At least he has been creative.
