Other than that it looks great and costmetically is in good condition.
One more thing, it's got the coolant pipes off a USDM WRX TD04 because I had to use the forester coolant pipes on my USDM TD04. It slightly interferes with the vacuum nipple on the actuator but it would be bent out of the way pretty easily or you may even be able to get a vacuum line on it just the way it is.
$75 shipped
