Bad fuel pump?
Bad fuel pump?
I am thinking tomorrow I will try swapping fuel pump assemblies. I realized if I ease into the pedal it pulls pretty good. If i just jump to 1/2 throttle for ex. just doesn't pull when the turbo is spooled. So my plan is to swap the entire fuel pump assembly from my touring wagon, to my sedan and sedan to the wagon. Can I do this with no issues? 92 wagon to 94 sedan. Also questioning the DP tomorrow I will check compression on the motor as well.
