What do you think about Warped Rotors?
This article by a company who designs performance brakes argues that warped rotors are merely a bad myth.
I've turned a few rotors in an automotive tech class and although the machine grinded more on certain spots on the rotors and on some spots not at all, visually I could not tell the rotor was warped as it spun on the machine.
I am in no way an expert or even experienced with brakes. Just for the record.
http://www.stoptech.com/tech_info/wp_wa ... disk.shtml
The "Warped" Brake Disc and Other Myths of the Braking System
by Carroll Smith
Myth # 1 – BRAKE JUDDER AND VIBRATION IS CAUSED BY DISCS THAT HAVE BEEN WARPED FROM EXESSIVE HEAT.
The term "warped brake disc" has been in common use in motor racing for decades. When a driver reports a vibration under hard braking, inexperienced crews, after checking for (and not finding) cracks often attribute the vibration to "warped discs". They then measure the disc thickness in various places, find significant variation and the diagnosis is cast in stone.
When disc brakes for high performance cars arrived on the scene we began to hear of "warped brake discs" on road going cars, with the same analyses and diagnoses. Typically, the discs are resurfaced to cure the problem and, equally typically, after a relatively short time the roughness or vibration comes back. Brake roughness has caused a significant number of cars to be bought back by their manufacturers under the "lemon laws". This has been going on for decades now - and, like most things that we have cast in stone, the diagnoses are wrong.
With one qualifier, presuming that the hub and wheel flange are flat and in good condition and that the wheel bolts or hat mounting hardware is in good condition, installed correctly and tightened uniformly and in the correct order to the recommended torque specification, in more than 40 years of professional racing, including the Shelby/Ford GT 40s – one of the most intense brake development program in history - I have never seen a warped brake disc. I have seen lots of cracked discs, (FIGURE 1) discs that had turned into shallow cones at operating temperature because they were mounted rigidly to their attachment bells or top hats, (FIGURE 2) a few where the friction surface had collapsed in the area between straight radial interior vanes, (FIGURE 3) and an untold number of discs with pad material unevenly deposited on the friction surfaces - sometimes visible and more often not. (FIGURE 4)
In fact every case of "warped brake disc" that I have investigated, whether on a racing car or a street car, has turned out to be friction pad material transferred unevenly to the surface of the disc. This uneven deposition results in thickness variation (TV) or run-out due to hot spotting that occurred at elevated temperatures.
In order to understand what is happening here, we will briefly investigate the nature of the stopping power of the disc brake system.
THE NATURE OF BRAKING FRICTION
Friction is the mechanism that converts dynamic energy into heat. Just as there are two sorts of friction between the tire and the road surface (mechanical gripping of road surface irregularities by the elastic tire compound and transient molecular adhesion between the rubber and the road in which rubber is transferred to the road surface), so there are two very different sorts of braking friction - abrasive friction and adherent friction. Abrasive friction involves the breaking of the crystalline bonds of both the pad material and the cast iron of the disc. The breaking of these bonds generates the heat of friction. In abrasive friction, the bonds between crystals of the pad material (and, to a lesser extent, the disc material) are permanently broken. The harder material wears the softer away (hopefully the disc wears the pad). Pads that function primarily by abrasion have a high wear rate and tend to fade at high temperatures. When these pads reach their effective temperature limit, they will transfer pad material onto the disc face in a random and uneven pattern. It is this "pick up" on the disc face that both causes the thickness variation measured by the technicians and the roughness or vibration under the brakes reported by the drivers.
With adherent friction, some of the pad material diffuses across the interface between the pad and the disc and forms a very thin, uniform layer of pad material on the surface of the disc. As the friction surfaces of both disc and pad then comprise basically the same material, material can now cross the interface in both directions and the bonds break and reform. In fact, with adherent friction between pad and disc, the bonds between pad material and the deposits on the disc are transient in nature - they are continually being broken and some of them are continually reforming.
There is no such thing as pure abrasive or pure adherent friction in braking. With many contemporary pad formulas, the pad material must be abrasive enough to keep the disc surface smooth and clean. As the material can cross the interface, the layer on the disc is constantly renewed and kept uniform - again until the temperature limit of the pad has been exceeded or if the pad and the disc have not been bedded-in completely or properly. In the latter case, if a uniform layer of pad material transferred onto the disc face has not been established during bedding or break-in, spot or uncontrolled transfer of the material can occur when operating at high temperatures. The organic and semi-metallic pads of the past were more abrasive than adherent and were severely temperature limited. All of the current generation of "metallic carbon", racing pads utilize mainly adherent technology as do many of the high end street car pads and they are temperature stable over a much higher range. Unfortunately, there is no free lunch and the ultra high temperature racing pads are ineffective at the low temperatures typically experienced in street use.
Therefore - there is no such thing as an ideal "all around" brake pad. The friction material that is quiet and functions well at relatively low temperatures around town will not stop the car that is driven hard. If you attempt to drive many cars hard with the OEM pads, you will experience pad fade, friction material transfer and fluid boiling - end of discussion. The true racing pad, used under normal conditions will be noisy and will not work well at low temperatures around town.
Ideally, in order to avoid either putting up with squealing brakes that will not stop the car well around town or with pad fade on the track or coming down the mountain at speed, we should change pads before indulging in vigorous automotive exercise. No one does. The question remains, what pads should be used in high performance street cars - relatively low temperature street pads or high temperature race pads? Strangely enough, in my opinion, the answer is a high performance street pad with good low temperature characteristics. The reason is simple: If we are driving really hard and begin to run into trouble, either with pad fade or boiling fluid (or both), the condition(s) comes on gradually enough to allow us to simply modify our driving style to compensate. On the other hand, should an emergency occur when the brakes are
cold, the high temperature pad is simply not going to stop the car. As an example, during the mid 1960s, those of us at Shelby American did not drive GT 350 or GT 500 Mustangs as company cars simply because they were equipped with Raybestos M-19 racing pads and none of our wives could push on the brake pedal hard enough to stop the car in normal driving.
Regardless of pad composition, if both disc and pad are not properly broken in, material transfer between the two materials can take place in a random fashion - resulting is uneven deposits and vibration under braking. Similarly, even if the brakes are properly broken, if, when they are very hot or following a single long stop from high speed, the brakes are kept applied after the vehicle comes to a complete stop it is possible to leave a telltale deposit behind that looks like the outline of a pad. This kind of deposit is called pad imprinting and looks like the pad was inked for printing like a stamp and then set on the disc face. It is possible to see the perfect outline of the pad on the disc. (FIGURE 5)
It gets worse. Cast iron is an alloy of iron and silicon in solution interspersed with particles of carbon. At elevated temperatures, inclusions of carbides begin to form in the matrix. In the case of the brake disk, any uneven deposits - standing proud of the disc surface - become hotter than the surrounding metal. Every time that the leading edge of one of the deposits rotates into contact with the pad, the local temperature increases. When this local temperature reaches around 1200 or 1300 degrees F. the cast iron under the deposit begins to transform into cementite (an iron carbide in which three atoms of iron combine with one atom of carbon). Cementite is very hard, very abrasive and is a poor heat sink. If severe use continues the system will enter a self-defeating spiral - the amount and depth of the cementite increases with increasing temperature and so does the brake roughness. Drat!
PREVENTION
There is only one way to prevent this sort of thing - following proper break in procedures for both pad and disc and use the correct pad for your driving style and conditions. All high performance after market discs and pads should come with both installation and break in instructions. The procedures are very similar between manufacturers. With respect to the pads, the bonding resins must be burned off relatively slowly to avoid both fade and uneven deposits. The procedure is several stops of increasing severity with a brief cooling period between them. After the last stop, the system should be allowed to cool to ambient temperature. Typically, a series of ten increasingly hard stops from 60mph to 5 mph with normal acceleration in between should get the job done for a high performance street pad. During pad or disc break-in, do not come to a complete stop, so plan where and when you do this procedure with care and concern for yourself and the safety of others. If you come to a complete stop before the break-in process is completed there is the chance for non-uniform pad material transfer or pad imprinting to take place and the results will be what the whole process is trying to avoid. Game over.
In terms of stop severity, an ABS active stop would typically be around 0.9 G’s and above, depending on the vehicle. What you want to do is stop at a rate around 0.7
to 0.9 G's. That is a deceleration rate near but below lock up or ABS intervention. You should begin to smell pads at the 5th to 7th stop and the smell should diminish before the last stop. A powdery gray area will become visible on the edge of the pad (actually the edge of the friction material in contact with the disc - not the backing plate) where the paint and resins of the pad are burning off. When the gray area on the edges of the pads are about 1/8" deep, the pad is bedded.
For a race pad, typically four 80mph to 5 and two 100mph to 5, depending on the pad, will also be necessary to raise the system temperatures during break-in to the range that the pad material was designed to operate at. Hence, the higher temperature material can establish its layer completely and uniformly on the disc surface.
Fortunately the procedure is also good for the discs and will relieve any residual thermal stresses left over from the casting process (all discs should be thermally stress relieved as one of the last manufacturing processes) and will transfer the smooth layer of pad material onto the disc. If possible, new discs should be bedded with used pads of the same compound that will be used going forward. Again, heat should be put into the system gradually - increasingly hard stops with cool off time in between. Part of the idea is to avoid prolonged contact between pad and disc. With abrasive pads (which should not be used on high performance cars) the disc can be considered bedded when the friction surfaces have attained an even blue color. With the carbon metallic type pads, bedding is complete when the friction surfaces of the disc are a consistent gray or black. In any case, the discoloration of a completely broken in disc will be complete and uniform.
Depending upon the friction compound, easy use of the brakes for an extended period may lead to the removal of the transfer layer on the discs by the abrasive action of the pads. When we are going to exercise a car that has seen easy brake use for a while, a partial re-bedding process will prevent uneven pick up.
The driver can feel a 0.0004" deposit or TV on the disc. 0.001" is annoying. More than that becomes a real pain. When deposit are present, by having isolated regions that are proud of the surface and running much hotter than their neighbors, cementite inevitably forms and the local wear characteristics change which results in ever increasing TV and roughness.
Other than proper break in, as mentioned above, never leave your foot on the brake pedal after you have used the brakes hard. This is not usually a problem on public roads simply because, under normal conditions, the brakes have time to cool before you bring the car to a stop (unless, like me, you live at the bottom of a long steep hill). In any kind of racing, including autocross and "driving days" it is crucial. Regardless of friction material, clamping the pads to a hot stationary disc will result in material transfer and discernible "brake roughness". What is worse, the pad will leave the telltale imprint or outline on the disc and your sin will be visible to all and sundry.
The obvious question now is "is there a "cure" for discs with uneven friction material deposits?" The answer is a conditional yes. If the vibration has just started, the chances are that the temperature has never reached the point where cementite begins to form. In this case, simply fitting a set of good "semi-metallic" pads and using them hard (after bedding) may well remove the deposits and restore the system to normal operation but with upgraded pads. If only a small amount of material has been transferred i.e. if the vibration is just starting, vigorous scrubbing with garnet paper may remove the deposit. As many deposits are not visible, scrub the entire friction surfaces thoroughly. Do not use regular sand paper or emery cloth as the aluminum oxide abrasive material will permeate the cast iron surface and make the condition worse. Do not bead blast or sand blast the discs for the same reason.
The only fix for extensive uneven deposits involves dismounting the discs and having them Blanchard ground - not expensive, but inconvenient at best. A newly ground disc will require the same sort of bedding in process as a new disc. The trouble with this procedure is that if the grinding does not remove all of the cementite inclusions, as the disc wears the hard cementite will stand proud of the relatively soft disc and the thermal spiral starts over again. Unfortunately, the cementite is invisible to the naked eye.
Taking time to properly bed your braking system pays big dividends but, as with most sins, a repeat of the behavior that caused the trouble will bring it right back.
I think this has been posted before, perhaps in discussions about cryo-treating. I tend to agree with these guys as it makes far more sense to me than the rotors being warped for the reasons they mentioned, but it's not something that I can prove. What I know and care is that cryo-treating eliminated the problem for me.
What is cryotreating?
http://www.cryo-parts.com/company.html
I "warped" rotors in a few months when I had them. Finally got sick of it and tried a cryo-treated set. They lasted 4 years and were so worn when I replaced them that they were nearly down to the vents. Still hardly pulsed.
I'll second cryo-treating rotors. I've had rotors on the Legacy for leaps and bounds longer than I ever had without cryo-treating them.
So that company seems to only do audio hardware. How do you get your brake rotors cryo treated?
Do they have to be new? Could I upgrade to bigger brakes from another subaru and have them lathed and then cryo treated?
What does it cost?
SLODRIVE
Post by SLODRIVE »
I have to vehemently disagree with the above article calling "myth" on warped rotors...Yes, brake pads can and do leave deposits on rotors that cause uneven braking, and I have seen this many times...but rotors warping from heat is a very real situation. I have done more brake jobs than I can count, and turned (and measured) literally hundreds of brake rotors. I also live at the base of the Rockies, so you can bet there's tons of cars cooking their brakes all the time. I think using a GT40 as an example is just silly...Geez, a purpose-built race car, with "race-car" brakes designed to take extreme heat, that will never heat-cycle its parts the way a street car does, never warped its rotors. ZOMG!
In all fairness, there are other factors that can warp rotors, such as uneven tightening of lug nuts, machining them too thin, dropping them during installation, or even improper storage of them on a shelf. Still, I have also seen plenty of cars where the brake rotors were warped after a hard mountain drive, and there was no question about the problem (rotors were measured for runout), or when it had happened; the brakes had been fine before. In fact, this was an issue when I was working at Super-Rupair in the mid '90s and we were dealing with Legacies and some of our mountain-living customers kept warping rotors. Hand-torquing all the wheels actually helped somewhat, but we found the best solution was upgraded brake pads and rotors. Normally machining rotors for someone who's having rotor problems is a no-no, because making the rotor thinner exacerbates the problem...a thinner rotor makes for a less effective heat sink, simple as that.
Don't get me wrong, that article has some very good information, but I would never agree that heat-related warpage is a myth. A thousand articles like this will NEVER replace what I've seen with my own eyes many times.
Uhhh...just my 2 cents? :)
http://www.slodriveracing.com
-And more!
The correct term really should be "Disc Thickness Variation". You are seeing variations in thickness at the surface level, not throughout the entire rotor.
Check out this thread on NASIOC and the animation posted by DBAsteve
http://forums.nasioc.com/forums/showthread.php?t=264636
SLODRIVE
Post by SLODRIVE »
Legacy777 wrote:The correct term really should be "Disc Thickness Variation". You are seeing variations in thickness at the surface level, not throughout the entire rotor.
Not trying to start trouble, but I'm not sure you're making a fair assessment of what you think I'm seeing. The only proper way I know to measure warpage on a brake rotor is to measure runout all the way around both sides of the rotor, as well as measuring thickness at various places. At this point, if you mark the high and low points on both sides of the rotor, you'll know right away if it's actually warped or has variations in thickness. Not only that, but on a decent brake lathe, it's easy to see if you're removing identical amounts of metal on each surface of the rotor to flatten it out, but at opposite ends of the rotor, it's clearly warped. If you have to machine metal away in more random places, then it's a sign of thickness variation. I know for a fact that I have seen rotors with over .008" of actual warpage, and yes, the rotor's thickness was fairly consistent all the way around in that case. I've also pulled brand new rotors out of the box and found them to be warped, although I'll admit that was a rare occurrence.
Again, I agree completely with the effects of material deposits on the rotors and I've seen that as well, including the variations in thickness. This was explained to me by one of the (better) NAPA Brakes sales reps a few years ago, along with how it's usually caused by drivers leaving a heavy foot on the brake pedal after stopping with hot brakes. That in and of itself doesn't mean at all that rotors won't warp. Cylinder heads do, right? :)
-And more!
I don't think neither one is completely implausible. I guess the article is kind of denying warping altogether, but I think they're both failure modes and with the burn marks in the shape of pads clearly visible on rotors from holding the brakes after a hard stop points to the likelihood of uneven deposits.
But whatever the failure, the cryo-treating fixes both.
As far as getting it done, forzenrotors.com was one place, but a Google search will find a bunch of matches. Many things are cryotreated as well, so you could call any cryo facility and I wouldn't doubt they do rotors. Still, I'd go with someone who specializes in it.
Some places you send them rotors, they treat them, and send them back. Others will sell you treated rotors direct. Went the first route with my OEM set, the second when I moved to WRX front brakes (which I don't really recommend for a regular driven street car due to the change in bias).
Not saying warped rotors can't happen, however I'd say most of the problems people have are related to pad deposits and DTV.
On cryo treating. I've used www.onecryo.com in the past with good results.
That's pretty close. Hour drive or so. But I filled out the form and sent it to them and got an error so I don't think it went through. The site is kinda of cheaply made and seveal images are not showing up.
Do you remember how much it cost?
That's the other guy I used. I can't remember which one I had to send the rotors and which one I ordered them directly from.
I don't remember off the top of my head. I'd suggest just giving them a call. The site may not be "top notch" but the service was good.
There are companies that do excellent work, but don't have a great website....they're just old school about how they market themselves, word of mouth primarily.
jamal
Vendor
Vendor
Post by jamal »
I don't think I'll ever bother with cryo treating since I used $30 rotors from autozone.
As for the warped rotor thing, the point is that most of the time warped rotors are not actually warped.
All rotors will change shape when heated, and the hat design has a lot to do with whether or not they get wavy. Generally a rotor will taper inward toward the top when hot or the whole thing will dish in or out.
Take a look at how the group N rotors are shaped:
That's specifically done to keep the rotor straight when it gets stupid hot.
In conclusion, a well designed rotor usually will not warp.
