Driveline shudder
L90EJ20at
Driveline shudder
Post by L90EJ20at »
I have had my 1990 FWD, and now also have a 1995 AWD. Was wondering if anyone could help with driveline. Sometimes it clunks when put in reverse, and when driving vibrates from center of car. Is there any maintenance that I need to do? The 95 was totalled in front, and when I looked under it seems the u-joint is binding. What should the u-joint behind the trans look like? Should it be touching itself? Thanks for any help..Anthony
I'm assuming you're talking about the 95 correct?
Any chance you could get a picture of the u-joint you're referring to?
