took out my a/c now my heat wont work
Dirty91Legacy
Post by Dirty91Legacy »
i took out everything mechanical related to the a/c but nothing electrical and for some reason my heat wont work.... or even the fan when i push like the heat switch i hear something moving and then it moves back when i press like vent but nothing ever comes out.... its a 91 legacy....please help
Does the fan work on "4"? You should check that the sensor behind the glovebox is plugged in. It's attached to the plastic box that holds the AC core.
Dirty91Legacy
i def. plugged it iin now it might have came out when i flocked my dash
