Clutch type diff vs. Viscus?
logan9691
Post by logan9691 »
Whats the difference between a clutch type LSD diff vs. a viscus type LSD diff.? which is better?
Thanks.
Logan
VF43 custom FMIC APEXI intake Invidia 3" TBE JDM Ver. 4 RA STi trans (4.44) SPT short shifter rear LSD WRX rear axels coilover suspension JDM 4-pot front brakes drilled slotted rottors Greddy EBC tuned 20G ECU sti 550cc injectors Jecs MAF walbro 255
I refer you to this excellent write up:
Subaru LSD's
It's about using Subaru LSD's in Datsuns, because they also use R160 Diffs, not to worry, it covers the different types of LSD's
monstaru
Post by monstaru »
depends on what you want to do with your car.....
if you are building an offroad type rig, go clutch i say....
if it is mainly concrete and asphalt.....vlsd
the differences are obvious i hope.ya know, clutch vs. viscuos......
i dunno , i have had both on cars, and do not have an issue with either if i was using them for what they were designed for.when i needed more i welded it.but thats a whole other talk show.......
cheers, brian
impreza_GC8
Post by impreza_GC8 »
Clutch type is always better.
-'97 Outback - EJ25 block/pistons/HLA heads, EJ22T crank/rods/ECU, EJ20G intake manifold/fuel rails/440cc injectors, VF8 @ 11psi. . . . Fuel cut > me
