So on a full charge my Legacy will start up just fine. but as the days and weeks go on it becomes more and more difficult to start. the ignition will just click and click and click and then finally start. after about a month or two of that the battery will completely die on me.
is it the alternator?
or some other wiring issue?
My batterys are slowly getting sucked dry.(91 L)
You don't have a amplifier hard wired to the battery do you?
No? Then I would check current through the alternator at rest. Might be shorted diodes in the voltage regulator.
Air-to-Water Intercooler, VF-39, 550 injectors, AEM FIC, stainless race header, 3" stainless exhaust, 75hp Nitrous, 150psi H2O injection, intake mods, stock: long block, 4EAT, ecm.
