came out of a '92 Liberty GX in Australia. A guy out in washington state imported it for his project, but it took about a year before he actually got it, at which point, he had scrapped the project. he offered it up for sale early last spring, so I bought it.
It has not been installed in a car since it's been imported.
Internals are much like those from an '87-'89 RX, except with an EJ bellhousing and VLSD center diff. Here's an RX box apart....only major difference is the pinion shaft.
1.59:1 lo-range from a part-time 4WD EA82 subaru box (quite common) is swappable if you want even lower gears.
$1400
