FS-MN: Australian Dual-Range EJ 5MT
Posted: Tue Dec 08, 2009 9:47 am
by Numbchux
AFAIK, the only one brought to North America. functions just like a standard EJ 5MT with a viscous center LSD etc. but, it also has a 1.196:1 lo-range reduction on the input shaft selected by a cable. it's like being able to switch from a 3.90 axle ratio to a 4.65 on the fly. great for short-track racing (RallyX, AutoX...), lo range for track gears, hi range for highway gears coming home.Uses a cable clutch, and needs a 3.90 rear diff.
came out of a '92 Liberty GX in Australia. A guy out in washington state imported it for his project, but it took about a year before he actually got it, at which point, he had scrapped the project. he offered it up for sale early last spring, so I bought it.
It has not been installed in a car since it's been imported.
Internals are much like those from an '87-'89 RX, except with an EJ bellhousing and VLSD center diff. Here's an RX box apart....only major difference is the pinion shaft.
1.59:1 lo-range from a part-time 4WD EA82 subaru box (quite common) is swappable if you want even lower gears.
$1400
Posted: Tue Dec 08, 2009 5:42 pm
by jdmleggy97
Do you have the lever for the selectible gear range?
Posted: Tue Dec 08, 2009 6:06 pm
by Numbchux
jdmleggy97 wrote:Do you have the lever for the selectible gear range?
nope. only linkage is the hi-lo cable. something to shift it would need to be fabbed.
Posted: Tue Dec 08, 2009 11:02 pm
by Heathyvt
Wish my trany had gone with my clutch.... arg no money, Some one needs to snatch this up! GL w/ sale
Posted: Thu Dec 10, 2009 12:31 am
by 206er
can you put a 4.44 front diff in it?
Posted: Thu Dec 10, 2009 8:39 am
by Numbchux
206er wrote:can you put a 4.44 front diff in it?
yes, you can. BUT, AFAIK 4.111 or 4.444 ring gears will have to machined down a bit to clear the low range gears (this might only be true if you're using the 1.59:1 lo range). I would highly recommend searching australian sites (like Ausubaru.com) for more info on this if you're serious about it.
