possible easy cruise fix?
kytomcmil
Post by kytomcmil »
after 2 years of no cruise i decided to start testing, have power to relay from bat but nothing on switched side. light came on but no cruise, under the dash i test the switches on the clutch and brake swing arms, no problems there. vaccuun diaphragm moves freely, wth man. so back under the dash, turns out theres holes in each swingarm with plastic plugs that the switch plunger contacts, clutch arn is missing the plug, put a very small u clip on and like magic i have cruise again
3 97 LGT's , Black Mica High-comp sedan MT, White Stock Sedan 5MT, Rio Red Wagon 4eat
Cool. Thanks for sharing, and hopefully it'll help someone out in the future.
