WTB Feeler: EJ22T Heads in Tacoma/Seattle
dkopp
Post by dkopp »
hello,
i wondered if anyone in the SEATAC area had a set of good, used EJ22T heads available. i was considering having delta cams do a head and cam job and thought i might be able to save on shipping by buying locally. of course, this would require the seller to deliver them for me, but i would absolutely compensate you for your miles and your time. i can even spring for lunch because that's only fair.
so, since there are far more leggies running around washington, maybe someone can help a fellow washington native out. inglemoor high school class of 93 (kenmore/bothell).
thanks for the consideration.
david
I have a set, they're dirty, but good. The engine they were attached to died (catastrophic oil starvation). Are you going to be in the Seatac area or are you wanting them shipped to Georgia?
