I have 900cc+ injectors that are low impedance top feeds. I need smaller flowing high impedance injectors of the same body type. The existing injectors were controlled by a Link ECU that is no longer in the vehicle. Luckily, I can revert to a stock ECU. The problem remains that these injectors are too damn big for the stock ECU. They also require a resistor box.
The problem I'm stuck with has three parts on the car
--custom fuel rails for these injectors
--this special JDM intake manifold that only works on phase 1 heads.
--this current manifold and fuel rail set being fitted for these "different" injectors that sit down into the manifold pocket.
--The manifold was also NOT machined to fit.
I've noodled with top feeds, but these injector bodies are different. It's not a side feed style of injector, but has a fat body like the pic below. I can't use the JDM grey tops OR the WRX style Denso/Bosch injectors. These injectors look like Bosch Ford units.
Thoughts? I think I can get high impedance injectors that fit these rails and I'm good to go. I'll be piggybacking a set of secondaries with a PerfectPower SMT6.
