Catch Can
logan9691
Catch Can
Post by logan9691 »
who's done a catch can setup on there car? I wanna see some pics of it so i can have an idea of what to do.
Thanks.
Logan
VF43 custom FMIC APEXI intake Invidia 3" TBE JDM Ver. 4 RA STi trans (4.44) SPT short shifter rear LSD WRX rear axels coilover suspension JDM 4-pot front brakes drilled slotted rottors Greddy EBC tuned 20G ECU sti 550cc injectors Jecs MAF walbro 255
Here's mine. You can't see everything I've done, but I ended up using a non-turbo IAC hose to connect the crankcase breather around the turbo so I could hook it up to the catch can.
http://main.experiencetherave.com/subaru/images/td05/07
You can kind of see the hose in these pictures
http://main.experiencetherave.com/subaru/images/td05/04
As for whether it works. I'd say yes.
http://main.experiencetherave.com/subar ... fault2.htm
I since put some mesh in between the inlet & outlet to help the oil condense and drop out.
http://main.experiencetherave.com/subar ... /catchcan/
logan9691
Post by logan9691 »
what size of greedy catch can did you use? they have a couple different sizes (9mm, 15mm).
Ummm....I think it was the 15mm one.
BTW, I'm quite amazed at what the mesh has done to help condense the oil. I just drove about 2,000 miles in four days, and I've got about 1.5" of oil registering in the catch can sight thingy. I've got a picture, but I've got to get it up to my server. When I do, I'll post it.
impreza_GC8
Post by impreza_GC8 »
I can clearly see where the hose that goes from the intake goes into the catch can, but where does that other hose go to? Looks like it moves toward the turbocharger? Where does it end? Thanks.
-'97 Outback - EJ25 block/pistons/HLA heads, EJ22T crank/rods/ECU, EJ20G intake manifold/fuel rails/440cc injectors, VF8 @ 11psi. . . . Fuel cut > me
Mattheww044
Post by Mattheww044 »
thats one clean ass motor josh :P
Thank you :)
