so from some of the info i have i know i need n/a fuel rails. i'm picking them up tomorrow.
but, i'm nut sure on install. does anyone have pics and / or part numbers of o-rings i may need.
Or, do these injectors drop right into the n/a rails.
the injectors are yellow tops out of an 06 sti.
thanks
Ryan
i'll have pics up in an hour
550 cc install questions
They drop right into the n/a rails. You don't have to do anything with the o-rings.
The only thing you need to do is remove the gray cover on top of the injector.
