To those with "connections", 6 speed cost?
PhyrraM
Post by PhyrraM »
And by "connections" I mean legal ones.
What is the "good deal" cost on a STI 6 speed? JDM or USDM.
Our Legacies already have the 3.9:1 rear end, so the swap should be as easy as clutch, flywheel, shift linkage, mount, and automatic driveshaft. A VLSD center diff is preferable to a DCCD one, but beggars can't be choosers.
Think one can be had for less than $2000ish? Seems too low to me, but I don't have connections.
ciper
Post by ciper »
You can use a five speed clutch with the 6 speed transmission.
Some 6 speeds use a 3.54 rear differential.
PhyrraM
Post by PhyrraM »
Interesting. Just the disc? Just the pressure plate?
I know the '07 uses the 3.54, and possibly some of the JDM, but by far most of them use the 3.9 we already have.
'06 up use a 3.545 rear end.
Depending on the tranny you get, you may need the infamous stub axles and seals. Aside from those, its a shifter linkage, driveshaft, and clutch away from bolting in.
It's soooooooo worth it.
PhyrraM
Post by PhyrraM »
But is $2000 reasonable? Not needing any of the rear end stuff the WRX guys need?
Most folks ASK for more, but never post what they ended up ACTUALLY letting it go for.
93forestpearl wrote:It's soooooooo worth it.
Worth what? I saw a USDM STI's 6mt with broken 2nd gear sell for $200 in about 15 minutes. I had emailed the guy as soon as it posted and he said I was 5th in line or something...
Worth the 30-year newer transmission design. The 6mt feels like butter compared to a 5mt. And has gears that are almost twice the size.
I don't know what used 6mt's go for these days. I bought mine back in '06 when they were an especially hot item. Needless to say I paid too much for it. I have no idea what today's market is like.
93forestpearl wrote:Worth the 30-year newer transmission design. The 6mt feels like butter compared to a 5mt. And has gears that are almost twice the size.
Interesting. The only 6mt subaru I have driven was a 7k mile dealer trade-in STI, and the clutch and gearbox really did feel good. The 5mt Subarus I've driven (and I have driven many) felt really bad. I assumed they were beat on. But I'm not really interested in the 6th gear, but the front LSD. Sure I COULD put one in my 5mt, but...
ciper
Post by ciper »
PhyrraM wrote:Interesting. Just the disc? Just the pressure plate?
No the entire clutch as a unit can be used. You can also use a 6 speed clutch on a five speed with the help of a dremel.
I think the my04 through early my06 had the 3.9 rear.
ciper
Post by ciper »
Redlined
Post by Redlined »
Near where I live is a STI specialist called Silverline Automotive. They sell kits for $4500 that include Trans, axles, driveline, and rear end.
Here's an 04 STI tranny swap for $4,200 on NASIOC
http://forums.nasioc.com/forums/showthr ... ?t=1898071
Selling a 2004 STi 6 speed swap, including:
04 STi tranny, only seen redline fluid, 78k mi
transmission x-member with oem mount
stock shifter assembly, with lever
6spd clutch fork and pin
driveshaft
rear diff with subframe
all 4 axles
like new oem clutch and flywheel
rear hubs
photos can be viewed here
PRICE DROP
selling swap for $4200 obo, buyer responsible for shipping. parts are in SE VA. paypal accepted, will split the 3% fee.
Parts located in VA near hampton roads.
Or just the tranny and shift linkage for $3,100.
http://forums.nasioc.com/forums/showthr ... ?t=1870566
Oh man, it keeps getting better and better. He's an 05 with way less miles for only $2,500!
http://forums.nasioc.com/forums/showthr ... ?t=1891026
