flywheel and clutch
flywheel and clutch
So I found a salvage yard that will give me a package deal for the 5mt swap on my t-wagon. I don't know the doner car yet but I wondered if I can purchase the flywheel and clutch before I know where the tranny comes out of. I think I can go ahead with a SS flywheel and clutch if I'm right?! The tranny I'm sure will be from a NA impreza with hydro I believe.
Yeah, you can't use a turbo flywheel & pp setup with an non-turbo tranny.
but cant you convert a pp setup to work with it?
ok so Should I just go with an RS style flywheel and clutch? That should work with most any na mt setup right? if so what years are good for that?
94 tleggy wagon, 22t with 2.5 dohc heads, pp6, tdo4, fmic, 3inch catless bpm turbo back, wrx brakes, MANY interior mods to list
