Headlights
cvt
Headlights
Post by cvt »
I just bought a 91 Legacy wagon. I noticed that the hibeam indicator on the dash is always on, even when the headlights are set to low beam. Also the driver's side headlight is very dim.
The red/white wire coming out of the harness for this headlight has been cut. The passenger headlight seems to be brighter than it should be, and when I disconnect the driver's side headlight bulb, it dims down a little to what seems to be a normal brightness. Now for some reason when I disconnect the passenger
headlight bulb with the dim driver's bulb still hooked up, the driver's side dim headlight bulb turns off.
Is this some grounding issue that I am having??
The headlights on these cars use a switch ground system. If someone has done some "modifications" chances are they messed this up.
Here's the headlight wiring for the canadian cars
(copy & paste the link in your browser)
Code: Select all
http://main.experiencetherave.com/subaru_manual_scans/FSM_Scans/Legacy_headlight_wiring_diag_(CA).zip
and US diagram incase the car was a US car
Code: Select all
http://main.experiencetherave.com/subaru_manual_scans/FSM_Scans/Legacy_headlight_wiring_diag_(US).zip
cvt
Post by cvt »
Thank you
