My turn for cooling fun
Posted: Tue Jan 12, 2010 6:19 pm
Well my "new to me" 94 NA 2.2L 4EAT Legacy wagon needed a new water pump as it was leaking when I got it home.
Swapped it out for a standard parts store pump and parts store thermostat.
Everything went together and apart like clock work.
Flushed the radiator while I had it out.
Filled it up with coolant and burped it .
Has been running great for the last 200 miles and 2 weeks.
I dont drive it often or far.
Although I have noticed that the dual cooling fans kick in as soon as its op temp on the gauge and stays on until I shut the car off. Basically , there always on. Puzzled me a bit.
Good heat in the car , great performance and 21 mpg city driving. No white smoke , combustion chambers look good via checking plugs . No oil in coolant or vice versa.
So the clincher was last night .
Drove from salem to portland via I5 at 65mph.
Drove great there , thats 30 miles.
on the drive back , the temp gauge started climbing past the 1/2 mark and got to about the 2/3 mark.
Turned on the heater fan for the interior heat and the needle dropped to normal.
Got it home this way and parked it in the garage.
Popped the hood with car off and grabbed top pass coolant hose = warm/hot
Grabbed bottom driver side coolant hose = BONE COLD.
Suspect no circulation of coolant .
I have NO bubbles as I have burped it numerous times and driving it around town the temp needle stays normal but the cooling fans will run the whole time.
Only happens upon long drives .
Today I will be removing the parts store thermostat , draining coolant and installing OEM subaru thermostat .
Lets see if that fixes it.
