Backup Light Bulb
drewriviera
Backup Light Bulb
Post by drewriviera »
What bulb do you use for the backup light bulbs on a 91 SS? The manual says "27 watt"...is this an 1157? Or....?
-Andrew
BSOD2600
Post by BSOD2600 »
Most bulbs have the wattage/voltage stamped/marked on them... have you looked if it does?
'11 WRX Limited
'94 TW | R.I.P.
subaru_styles
Post by subaru_styles »
should be an 1156. 1157's are dual fillament
1994 SS "JDM-OEM"
1994 gt wagon, next build
1994 turbo wagon
drewriviera
Thanks!
