1. 90* elbow hits intake runner. I still got the intake to fit kind of. (bigger concern is the pressure side)
2. When i downshift from say 5th to 4th my boost guage boosts up to around 9psi and than looses the boost to around 4psi until the rpm's climb to about 5K, and then its back up to "full boost". It kinda feels like a misfire but not. As it wraps out trough the rpm band i can feel the car loosing power than gaining than loosing again.
i replaced all the vacuum lines and pcv too, and 55 sti injectors. No chip as of yet.
The more i think about it the more i believe it had this issue before the swap. For example: cruising in 5th and than flooring it, still in fifth it would sometimes pick up speed quite nicely, but then loose power/boost after a few seconds. Any ideas? I tried to make this clear. I will drive it some more tonight and see how it does, but as of now, the car pulled harder with the old set up. (the car has a MBC but its not turned up much
