JECS MAF Question
CAV3MAN227
JECS MAF Question
Post by CAV3MAN227 »
I finally found a Jecs Maf sensor. I found some info about the jecs maf in the forums here especially from douglas vincent, but didn't quite answer my thoughts.
My car is just above stock but my goal is 440 injectors, td04, 3in dp, pp6. My question is when can i use this? can i use it now? or do i need something else? any links or advise is appreciated!
BSOD2600
Post by BSOD2600 »
Once you drop in the TD04, good idea to put in the JECSs. Only real way to tell when it's needed is data log the MAF airflow/voltage with your boost levels. Once the Hitachi MAF is near 5V or airflow of ~155 g/sec, it's maxed out. JECS also is 5V but ~215 g/sec max. You really should be using EM when you swap in the JECS too, due to the different airflow vs voltage scaling.
'11 WRX Limited
'94 TW | R.I.P.
CAV3MAN227
is that where the perfect power, pp6, comes into play? or some other form of em?
I'm not sure how much the perfect power is, but the current stg 2 revtronix chip will take advantage of your current mods, and is around $250. I'm waiting on their user tunable chip, though, which should/might come out this year.
wtdash
Post by wtdash »
When I ran the JECS on the stock ECU programming, it ran lean....even w/the 440cc injectors.
I recommend you run the JECS only w/the Revtronix or other EM that can manage it properly.
Td
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
CAV3MAN227
wtdash wrote:When I ran the JECS on the stock ECU programming, it ran lean....even w/the 440cc injectors.
Td
can the perfect power manage that?
CAV3MAN227
Re: JECS MAF Question
-bump to find an answer!
Florin1
Post by Florin1 »
All i've always read was that it runs really LEAN!! Unless you have engine management. What i want to know is can i drop it in if i'm running 525cc. My car is on stock ECU while i'm waiting on the RobTune. I'd like to drop my Jecs in, because my car is just DUMPING fuel at the moment.
1994 Legacy Sport Sedan.
1991 Legacy Sport Sedan.
wtdash
Post by wtdash »
CAV3MAN227 wrote:-bump to find an answer!
Did you check the PP6 site for info? Their documentation should tell you.
GL,
Td
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
wtdash
Post by wtdash »
Florin1 wrote:All i've always read was that it runs really LEAN!! Unless you have engine management. What i want to know is can i drop it in if i'm running 525cc. My car is on stock ECU while i'm waiting on the RobTune. I'd like to drop my Jecs in, because my car is just DUMPING fuel at the moment.
W/out a wideband to check your AFR, you'll be taking a chance. If you're playing w/this type of stuff, you'll want one anyway, so I'd start shopping. I paid $100ish for my used LC1 about 2 years ago on ebay.
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
brweber352
Post by brweber352 »
My understanding, WHICH IS VERY LIMITED.
Any time you change to a different MAF, there has to be some sort of rescaling done, airflow=voltage. I believe this is usually done with a piggyback of some sort or Stand Alone EM.
Take these words as coming from an unexperienced NEWB!
Brian
93'TLegWag171k StockBlock,TD05,HallmanMBC,530cc,Walbro255,shortram,LWpulley,DIS-2,MSDcoil,cxrFMIC,trans cooler/external filter,WRX wheels/brakes,CES w/Borla muffler,QTP elec cutout,REVchip2,KYB GR2,GroupN tops/all fr bushings,STImounts,GSD3 tires,LM-1,etc
Just swapping MAF's or injectors and expecting things to be ok is not good. Will the engine run...probably....will it run correctly, no.
The main issue is MAF sensors have a non-linear response curve. So there may be an area that the AFR's are ok, but another area where they are no way near being correct. So yes, this is why a piggy back or some form of engine management is needed to scale the entire MAF range properly.
There are some engine loading calculations that are factored off the MAF sensor, which can affect other things as well.
Mattheww044
Post by Mattheww044 »
I just bought a brand new in the box innovative lc-1 wideband that came with the gauge, controller, sensor, all the discs and manuals, etc. for about $190 from ebay. The seller was loose bolt motorsports. That is a SMOKING deal, and its new in the box. Im very satisfied with it, besides the fact that my car runs really rich with stock injectors....:( any ideas?
wtdash
Post by wtdash »
Mattheww044 wrote:I just bought a brand new in the box innovative lc-1 wideband that came with the gauge, controller, sensor, all the discs and manuals, etc. for about $190 from ebay. The seller was loose bolt motorsports. That is a SMOKING deal, and its new in the box. Im very satisfied with it, besides the fact that my car runs really rich with stock injectors....:( any ideas?
Hey Hijacker :-)
Did you get your other CEL issues resolved? Until you're running 100% code-free, any AFR testing will be suspect.
(Do I sound like I know what I'm talking about yet ? Well, don't give me too much credit.) :-)
TD
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Mattheww044
sorry. didn't mean to hijacking the thread, but that is a really good deal, and if you are talking about swapping injectors and mafs then a wideband is a must
Ok so to hijack the thread again (Josh your input is needed here) i have an emanage that i wish to tune my SS with. what about getting a wrx maf to tune with that and the "Big maf" upgrade?
That should be doable with the emanage. I don't know how's it's setup, but if it's like any other piggy back (I'm assuming it's a piggy back) you should be able to do that.
