93 legacy wagon rear perch/top hat/tapered springs issue
darklord
Post by darklord »
First Post :)
Car is 1 month new to me
Ordered rear GR2's and Top Hats (rubber inside mount was destroyed allowing clunking, and shocks were totally gone).
On taking the old stuff off, I found out I had tapered springs and a one piece tophat/perch...
I thought this was only on the earlier models..???
So what to do?..
Return the Top Hats and buy locally ($$) to ensure I get a One piece design, or buy the spring perch?
Any other cheaper options?
Cheers
Welcome.
You have two choices, you can either find a set of the non tapered springs and perch from a junkyard to swap over.
Or you can get new mounts that are meant for the tapered rear springs.
epicfail
Post by epicfail »
Must've been previously swapped in as entire units.
Were it me, I'd take this opportunity to replace all four springs w/ upgraded/higher-rate springs.
[quote="RJ93SS"]u fail, epicly[/quote][quote="evolutionmovement"]Don't do drugs, kids, men may not need nipples, but we look a lot funnier without them.[/quote]
